2 gang light switch
Old 11-03-13, 08:40 AM
E
2 gang light switch
I have just removed a 2 gang dimmer switch to be replaced by a standard 2 gang switch and having trouble getting the 2 lights to work independently, the switch is the only one in the room to operate the 2 lights so just 1 way on each light, the wiring is 2 reds and 1 yellow there was a link wire on the dimmer but forgot the combination , any help please,
Old 11-03-13, 08:47 AM
Received 1,112 Votes on 1,032 Posts
Welcome to the forums from the UK.
It would make sense that the yellow wire would be the one connected to both switches.
Do you have a meter where you can check voltage ?
Only one wire would have power always on it when checked to neutral or ground.
Old 11-03-13, 09:00 AM
E
yea will check voltage tomorrow, i tryed linking the yellow to the common teminals and 1 red to l1 and the other to the other l1 terminal but switching 1 swich on turns both lights on
Old 11-03-13, 10:28 AM
E
any other suggestions be welcome
Old 11-03-13, 12:26 PM
Do you have any type of meter or voltage tester ?
You need to find the hot wire of the three wires that are present.
