Ceilling + wall lighting conection
Received 0 Votes
Hello all
This is my first post here and should not be my last.
In my bathroom i have a light on the ceiling and i have added on the wall another lamp. The lamp on the wall is installed just next to the wall switch so all the electrical is all there. Now in the electrical box here is what i got. This is a 2 gang electrical box because in this box there is the light dimmer + there is also the timer for the exhaust fan. Just before i go any further all of my lights are all Del dimmable lights. Now in the 2 gang box here is how the electrical goes. In the box i got from the back got 2 white tied together + 1 red going to dimmer red then i got 2 blacks 1 going to fan control + the other black they go to again fan control + light dimmer.
I have tried a few things to try to make my wall light work with the dimmer switch but was not successful ether the wall light was working well and the ceiling light was very low in voltage witch was not good, now i got the power up perfect but i can on control my ceiling light and not my wall light.
Any help would be appreciated
Thanks
Thanks
Welcome,
The white from the new light gets spliced to the white bundle. The black from the new fixture splices to the switched black on the dimmer. If the light does not dim, switch the black to the other lead on the dimmer.
Received 0 Votes
Thanks for the reply
I am not to good in english so what do you mean exactly by splice. Do you mean send the white from new fixture to white bundle. I was also thinking of putting a 3 way dimmer
Received 0 Votes
Case closed
You ever heard of the song Finally Well i have done it. Everything is working fine wow i am an electrician. No but this one was hard for me usually they are simple to do but this one for me was hard.
Many thanks to you
Case closed
Many thanks to you
Case closed
Previous Thread
Next Thread
