Wiring Switched Light
Received 0 Votes
Background: Just purchased house....prior owners did addition and made old kitchen an office. There was a switched light above the original sink location. I want to install pendant light there. Pendant light has 1 black, 1 white and 1 ground.
Ceiling outlet has 1 ground capped off, 1 single white capped off, 1 single black capped off, and 1 black/1 white capped together. Wall switch is still present.
Am I correct to attach pendant black to single outlet black, pendant white to single outlet white, grounds together, and leave the 1 black/1 white capped together?
Photo of ceiling outlet attached.
Welcome to the forums.
Yes.... that current white/black splice remains untouched. That is a switch loop connection.
That connection/loop tells you that you'd find a white and a black wire on the switch.
Now.....instead of leaving that wire colored white.....we'd remark it like red or maybe blue so that it wasn't confused in the future as a white/neutral wire.
Your new light connects to the two single wires and ground.
