Low-voltage pendant - bad connection @ bulb
Received 0 Votes
Hi,
I have a low voltage lighting track in my kitchen. It has 4 down-lights and 2 pendants attached. Two of the down-lights are having issues with the bulb connection. Basically.... the lights will go out and if I jiggle the bulb, they come back on. I've replaced the bulbs, same issue so I'm pretty sure the issue is at the fixture itself.
I'm thinking I need to clean the connections? What is the best way to do this and is there anything else I should be looking at?
Thanks
Scott
Thanks
Scott
