CF in enclosed fixture
Old 01-18-14, 05:21 PM
A
I have a "jelly jar" fixture above my backdoor.
Can I use a CF in this type of enclosure?
I know CF's used to have issues with totally enclosed fixtures, is that still the case?
I know it probably is a proprietary issue but generally?
Old 01-18-14, 07:34 PM
Mr.Awesome's Avatar
I put 13W cfl`s in my front and back jam jar lights 3 years ago and they`re still rockin`.
Old 01-18-14, 08:23 PM
T
They are technically not supposed to be used in totally enclosed fixtures because the heat buildup affects the ballast. Same reason you're not supposed to burn them base-up in a recessed can light or ceiling fan unless it is specifically rated for it..
But that said, people do it all the time. While I doubt it is an actual fire hazard, I have noticed that it definitely adversely affects its useful life.
Old 01-19-14, 08:25 PM
Nashkat1's Avatar
Received 2 Votes on 2 Posts
I have a 23W (100W "equivalent") dimmable CF lamp installed base-up in the schoolhouse globe that's part of the fan over our dining table. The control is an SOP dimmer - not CFL rated. The lamps last 2 years or more.
