Wiring pendant lights
Hi I am trying to figure out how to take three single bulb pendant lights and wire them together to create one light fixture? any help would appreciated thanks
Temporarily Suspended
I remember installing something like that which had all three lights already together has one fixture. There was no need for 3 separate boxes. Otherwise, the hot lead from the switch, is only going to go to one junction box. The other 2 lights have to be tapped into that box.
yes exactly so would I just connect the wires of the three lights together to a lead that connects to the junction box? its not a pre manufactured fixture its a DIY type idea
The wiring part is fairly straightforward and we can help you with that.
The part that confuses me is how to you plan on hanging three pendant lights with one canopy ?
It is brand new construction but yes I will make sure i have a tester to double check the power is off, I had planned on just making the single home in the canopy larger and putting the combined wires through that? I have seen a ton of DIY lights made that way should I not do that?
Combining Pendants
