Want to install non-UL listed light fixture
Received 0 Votes
I'm looking at a light fixture that I want to buy off Etsy (and install in a home). I wrote the manufacturer and this is his response. Should I be concerned about his practices? Should I be concerned about installing a non-UL listed light fixture after inspection as he mentioned?
It is not UL listed. It is made from all UL listed parts.
The UL listing process costs about $3000 plus costs for each product, so for my small scale production it is cost prohibitive. I do, however, follow the UL1598 procedures in the fabrication of all my fixtures.
If you are going to be using this fixture in a commercial application, most municipalities have a process for approving non UL listed fixtures and I am happy to supply photos, diagrams, and specifications to your local electrical inspector to facilitate that approval.
From my understanding, after the inspection, a homeowner can install pretty much anything they like in a single family dwelling.
To be safe, I would give the inspector a call on Monday, just to ask about the process, or what they would need to approve them. Or wait until after the inspection, to install.
What do you find appealing about this fixture that you haven't seen in any UL listed fixture?
FWIW, it sounds like the manufacturer gave you a straight-up answer. You can follow the process he suggested if you'd like to.
Received 0 Votes
It's appealing because it's a custom-built art piece. As I mentioned, it was found on Etsy. I'm guessing that such pieces of art are not uncommon things to be found on that Web site, as homemade stuff (all kinds of things, not just electrical fixtures or devices) is exactly all that is showcased there.
How about this: If you're willing to show us the piece, we might be willing to help you look for similar pieces that are listed.
Have you followed through on the process of finding out whether your jurisdiction will approve it?
Received 0 Votes
https://www.etsy.com/listing/1117932...malleable-iron
I haven't followed through yet because I am swamped at the moment. I will check with them ASAP, but I have other priorities at the moment.
Received 0 Votes
Or even better, go with these:
Industrial Wall Light | The Black Pipe MB Sconce
Metal Lamp Guard | Heavy Duty Bulb Cage | Brass and Black
Thanks for the help!
Received 0 Votes
Go For It.
It's pipe, some wire and a lightbulb. It's not going to burn your house down, we run wire through conduit all the time, in fact, it's the most secure way to run wire.
No inspector I have ever met looks for the UL sticker on light fixtures.
There may be some insurance implications, but even then these are UL listed parts, so putting them together in a certain order should be fine.
