Wobbly fan because of ceiling finish
Received 0 Votes
So I moved into my place a while ago and have been trying to figure out how to fix this Wobbly fan, I know you can get weight balancing kits but I'm not sure this would help. The problem is the fan doesn't fit flush against the ceiling because of the textured finish. If you push the light one way it's nice a quiet. I've tried folding paper under the mount and that works, but would like something a little more permanent,
As Ray says, most likely your ceiling box is not fan rated and merely hanging by the nails in the joist. Here is an example of a fan rated box. Yours needs to come out and a sturdy box needs to be installed. Note the difference in size and location of the screws that hold your bract to the box.
But keep in mind that the fan mounting does not make a solid connection to the ceiling, i.e. it's not bolted to the ceiling; rather it hangs from a ball & socket arrangement on a mounting plate bolted to the box although one of the flush-mount variety may be different, all mine are on down rods that hang as described.
