Leviton 9382 Fluorescent Light Switch Not Available
Old 02-06-14, 06:11 PM
I
Separated from: http://www.doityourself.com/forum/li...ht-switch.html
MacAnthony,
What did you finally do to fix your problem? I have the same issues with my tank light, the switch "Leviton 9382" is no longer in production, saw someone found a source selling them for crazy price $40. I tried a regular push button switch, all it light-up is the ends of the bulb.
Old 02-06-14, 07:56 PM
Received 1,316 Votes on 1,216 Posts
Welcome to the forums.
The Leviton 388 will also work for you. It's still available but is also a tad pricey.
Can be found at amazon for $25.
You can also wire in a starter socket and a starter that is sized to the wattage of your tube.
You can also replace the ballast with an electronic one and eliminate most future problems.
