LED can light does not come on instantly
Old 02-08-14, 11:34 AM
F
I installed an LED can light in my stairwell, but it takes a second or two after flipping the switch to come on. Never had an LED, but can't imagine that's normal. Any advice on this?
Old 02-08-14, 11:36 AM
Received 1,408 Votes on 1,303 Posts
Yes... that could be normal depending on what the bulb or fixture is using for a power supply.
An incompatible dimmer inline could also cause issues.
Old 02-08-14, 12:23 PM
F
"depending on what the bulb or fixture is using for a power supply"
What do you mean? Is there a way to fix that? A dark stairwell is not a good place for a slow light.
Old 02-08-14, 12:31 PM
Some bulbs come right on. That would require a bulb change.
If you bought the can and light as a kit... what is the brand and model number.
Old 02-08-14, 12:41 PM
F
Well what I did was, the night before the plasterer was coming, I realized I hadn't swapped out the old fixture in the stairwell. I didn't have a can on hand, but I did have a retrofit kit. So I just cut a hole in the drywall, and mounted the retrofit into the hole. I snipped the socket off and connected the wires to the existing power. Last minute improvise.
Old 02-08-14, 12:45 PM
F
oh forgot......... it's a Sylvania RT6 Gimbal
