Timer Switch with Dimmer
Old 02-11-14, 03:53 AM
R
I would like to install a programmable timer wall switch with a dimmer capability on a 3-way circuit (2 switches to operate the light). As there is no such device, can I install a Dimmer on one of the switches and the Timer on the other? Not sure if this will work. Would appreciate advice. Thank you.
Read more: http://www.doityourself.com/forum/li...#ixzz2t0sXWM64
Old 02-11-14, 06:19 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums!. You will have two scenarios to overcome. First you'll need a neutral in the switch box where the timer is located on some models. Often there is not a neutral available. Second, the dimmer/timer will need to be 3 way compatible. The one switch location can house both the dimmer and timer, but the other location will most likely just have a regular 3 way switch installed. No they can't be installed in different locations since you want them to perform in tandem.
UPM ETW193 Programmable Wall Switch Timer, 500W - Smarthome can be adapted for SPST or 3 way with jumpers. See the installation manual.
Old 02-12-14, 09:16 PM
R
Thank you for the insight; that is most helpful. I will try the UPM ETW 193 ...route as you suggest. Much appreciated.
