Go Back  DoItYourself.com Community Forums > Electrical, AC & DC. Electronic Equipment and Computers > Lighting, Light Fixtures, Ceiling and Exhaust Fans
Reload this Page >
Ceiling Fan, 3 way light, single switch fan, existing rough in- Can I? with diag
Old 02-24-14, 07:08 PM
I have a project that has existing wiring in place. I am trying to make due with what I have and see if I can get a ceiling fan to work as follows:
It's a bedroom with a fan box and switch boxes by each door. Near 1 door I want one switch to control the fan blades. The remaining switch and the other by the other entrance should be a 3-way.. both controlling the light alone. The fan should work independently of any light switch. That's the goal!
What I have diagnosed is as follows: See the attached rough sketch:
1. Power is to the double switch box.
2. From switch box to fan box there is a 3wire and a separate 2 wire with ground.
3. From the other switch box there is a 3 wire with ground.
I had it kind of working but the fan has a single hot wire for both the fan and the light. Thanks for any help.
Old 02-24-14, 08:58 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
You need to get a wire up thru the fan for the light. It's usually blue or a wire with a stripe.
I left the grounds out of the diagram but they need to also be connected.
Old 02-26-14, 08:36 PM
Thanks for the very nice reply. It looks then like I can get it to work. From your excellent diagram, I'll need a 3 way switch in both boxes for the light to work as planned...
In the light box, I am going from memory but you are correct. There is are several wires with one set for the light and the other for the fan but I think I understand your labelling in the box.
Again.. thank you very much!
Joe.
Old 02-26-14, 09:24 PM
You're welcome...... if you have any questions feel free to ask and someone here will help you out.
Old 03-02-14, 08:32 AM
PJMax,
I did this yesterday and it worked great. The 3way switches I have are a little odd but when I notice your color coding on the switches on your diagram and followed it.. it worked just great. Thanks very much... I am posting a similar 4 way scenario for this same project. Thanks again.
Old 03-02-14, 09:50 AM
Great news..... you're welcome
With a three way switch....as long as you put the common wire on the dark screw.... you can't go wrong.
