Splicing in a ceiling fixture to an existing switched line
Old 03-23-14, 12:58 PM
Need help Splicing in a ceiling fixture to an existing switched line
Hi all, I'm new to the boards thanks for all your time.
I started a project that I thought would be simple. Turns out I hit a snag. I am attempting to tie a ceiling light that is un-switched to a line that feeds the bottom half of an outlet that is tied to the wall switch.
I assumed, wrongly; that the load was a simple 14-2 romex. Turns out I cut into a 14-3.
I want to spice in a new 14-3 feeder to the ceiling box but, the light fixture is equipped with white, black, and bare tales. Which wires from the new feeder should I connect to the light fixture?
Old 03-23-14, 01:06 PM
Received 1,525 Votes on 1,408 Posts
Welcome to the forums.
What three wire cable did you cut into ?
It would be normal to find a three wire cable to the switched receptacle.
We need to be clear what you have and want to do.
Old 03-23-14, 01:09 PM
It is the cable that feeds the outlet from the switch. I have new 3 wire cable to make the splice. But my fixture is 2 wire.
Old 03-23-14, 01:12 PM
Ok... a three wire cable from the switch to the receptacle is common. You only need to run a two wire cable not three. Where do you want to connect the light..... at the receptacle or the switch box ?
Old 03-23-14, 01:39 PM
I wish it was that simple. I have already cut the cable in the ceiling thinking would need to splice an existing line. I never gave a thought to feeding a new cable to the box.
Old 03-23-14, 01:51 PM
Ok.... so you've cut into the cable that goes from the switch to the receptacle. Now you will either have to add a splice box or two if the cable is too short to work with. You will most likely just need the red and white for your ceiling light to work with the switch.
Old 03-23-14, 01:58 PM
Thanks for the reply. I'll post back when the results are in.
