Help with light switch, old wiring
Old 03-24-14, 04:23 PM
I'm replacing a dimmer switch with a 1 pole toggle switch.
When I removed the dimmer switch, there were just two black wires connected to it with wire nuts. There were also two other wires connected with a wire nut with a third short wire exposed. This exposed wire was not connected to the dimmer switch.
Is the exposed wire the ground that I should hook up to the green screw on the 1 pole switch? Also, once I disconnected the dimmer switch, other lights in the house will not turn on even if the fuse is turned back on.
Old 03-24-14, 04:29 PM
Received 4,154 Upvotes on 3,730 Posts
You must have missed a splice in passing. You said there were two black wires connected to the dimmer. What color are the other two wires that were connected together ?
Ground wires should be green or bare only.
Old 03-24-14, 04:32 PM
They are old threaded wiring so I can't even tell what color they are.
Old 03-24-14, 04:41 PM
Here's a picture of all the wires in the box as they were when I pulled out the dimmer switch.
Old 03-24-14, 04:53 PM
Any help is greatly appreciated. There are three rooms with no lights now.
Old 03-24-14, 05:40 PM
We connected the bare wire to the common screw on the switch along with another black wire and the red wire to the other screw. Every other light worked but my switch did not.
Any ideas?
Old 03-24-14, 06:25 PM
ray2047's Avatar
There is no bare wire in your picture and only 3-way switches have commons. If it is a 3-way switch you have the wrong kind of switch based on the dimmer in your picture.
Old 03-24-14, 06:32 PM
Interesting..... looks like a handi-box with no connectors. Are the wires just stuck thru the holes ?
Can you tell me how many wires come into that box. It looks like two cables and five wires.
Old 03-24-14, 08:27 PM
ray2047's Avatar
Is this the wire you called bare? Looks like a wire missing insulation and not safe.
Old 03-24-14, 09:04 PM
Actually.... now that I look at it again.... it would appear to be a mud ring on 4" square box.
Old 03-25-14, 06:28 AM
All wires are insulated. We got it to work by connecting a red wire to one side of the switch and the black wire to the other along with the short wire coming from two other black wires that were connected.
Old 03-25-14, 06:39 AM
Here's how I hooked the switch up. This light must be the first on the circuit of 4 rooms.
Old 03-25-14, 07:02 AM
Glad you got it working. Thanks for letting us know the outcome.
