Fire Rated Downlights
Old 04-04-14, 04:17 AM
G
I have a plasterboard ceiling and timber joists. Are fire rated a necessity?
Old 04-04-14, 06:31 AM
Received 1 Upvote on 1 Post
Only if it is a fire-rated ceiling (ie: if this is an apartment with another unit above). Otherwise if this is in your own house, then no. The only thing you would need to be concerned with then is if there is insulation in the ceiling, the can must be IC (Insulation Contact) rated.
Old 04-04-14, 09:37 AM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
If the space above is your attic, the housings should also be rated AT (air tight).
Old 04-04-14, 10:13 AM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
And IC rated.
