3 way switch driving me crazy
Old 04-17-14, 09:47 PM
R
I am trying to replace a 3 way switch but I cant seem to get it working right. Its an old house and I am pretty sure the power is coming from the light first. There are only 3 wires in each switch box (and the colors don't match so I assume there is a junction box or two somewhere. I think I have the common (hot) in the first switch coming from the light. I have tried all three wires in the second box as the common but noting seems to be working. Anyone have any ideas? I thought I may have the wrong hot in the first box, but I put up my test light on the black and any other wire and it comes on. The light does not come on with any other wire combo.
Old 04-17-14, 10:22 PM
ray2047's Avatar
Guessing won't help. Pull the light and see if you have a cable that measures 120 volts black to white when disconnected.
First you need to determine where power comes in so pull the light and begin there.
To determine if a wire is hot you must disconnect it and measure to a known good ground or neutral*. However keep in mind only one of your two commons have a wire that is hot when disconnected. .
Pull out the switches, look in the back of the junction box. Did this ever work? Is this cable or conduit? What are the colors.
*Use ans extension cord as your reference neutral when determining if a wire is hot if there is no ground.
