Adding a ceiling fan with switched outlet
Received 0 Votes
Alright guys so I am installing ceiling fans in my 3 guest rooms. None of the rooms have any wiring for them but all rooms have a switched outlet. I have already ran my 14-2 wire from my fan boxes to switch boxes. Now I am lost. In my switch box I have single pole switch with white black and ground. Then in the outlet box that the switch controls I have 2 sets of 14-2 wires. I have white and black wire nut together, one black going to bottom right of outlet, one white going to top left of outlet and none of the tabs on side of outlet are broke. And grounds are tied together and go to ground of outlet. What do I need to do to have the fan working on one switch and have the outlet continue to be switched?
Thanks
Brandon
Thanks
Brandon
From a previous reply here is basic instructions:
Switch box is better because there is a maximum number of wires a box can hold. Run 14-3(+ground) from a fan rated ceiling box to the switch if it is a 15 amp breaker. Run 12-3 if it is a 20 amp breaker. If the receptacle has the tab on the brass side removed replace the receptacle with one with the tab intact.
At the receptacle:
At the receptacle:
- Disconnect all wires except grounds.
- Connect all blacks to a pigtail.
- Connect all whites to a pigtail.
- Connect the black pigtail to the brass side and white pigtail to the silver side of the receptacle.
- If any red wires stop and post back for further instructions.
- Connect the whites to each other.
- Connect the blacks to the switch.
- Connect the grounds to each other and pigtail to the box if it is metal. Pigtail to the switch if a nonmetallic box.
- Blue and both blacks connected to each other.
- Whites connected to each other.
- Red not used if a single switch.
- Grounds connected to each other and pigtailed to the box if metal.
Received 0 Votes
ok. I want to make sure I understand this. Attach the black pig tail wire to the top right brass screw and attach the white pigtail wire to the bottom silver screw? And then in the switch box connect the white wires from the outlet and from the fan together and then attach the black wire from the fan to the switch and connect the black wire from the outlet to the other switch? Do the black wires need to be attached to the top or bottom screw of the switch?
If you want the receptacle to still be switched you will need to run additional cables.
