H Track lighitng - what screws to use?
Old 05-29-14, 06:08 AM
D
Received 1 Vote on 1 Post
I am about to install H track lighting for the first time. The lighting track came without mounting hardware. What size screw should I use?
Old 05-29-14, 07:07 AM
P
Received 632 Votes on 584 Posts
How large and heavy is your lighting and what are you attaching it to?
Old 05-29-14, 03:59 PM
D
It is a 6 feet track. I will be attaching about 4 small line voltage spots.
Old 05-29-14, 04:16 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
I would use toggle bolts.
Old 05-30-14, 03:17 PM
D
I was thinking to use nylon self drilling anchors. I am guessing the weight rating is reduced with ceiling installation a bit over wall/hanging installation?
Old 05-30-14, 03:42 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I wouldn't trust plastic anchors. In a wall the force vector is only about 90 so only a small percentage of the weight is acting on the anchor to pull it out but in a ceiling the force vector is a 180 so the whole wight is trying to pull it out. You could use molly screws also.
Old 05-30-14, 03:43 PM
P
It all depends on what your mounting to. You never said but it matter if it is wood, sheet rock, plaster or concrete.
Old 05-30-14, 04:13 PM
D
It is a sheet rock ceiling
