Ceiling lights
Old 06-05-14, 11:20 AM
D
Ceiling lights
Ceiling lights were working but now they are not.
I installed a new "led" bulb in one socket to have a different light source. That's the only change. The switch is a dimmer.
1. At the ceiling 1 black, 1 white and a ground.
2. At the switch 1 red, 2 whites capped off, and 2 blacks.
3. the dimmer switch wired to the 2 black wires.
Is the dimmer switch the problem, if so how do I connect a regular switch so the lights will work again.
Thanks
Old 06-05-14, 12:01 PM
ray2047's Avatar
The dimmer should have been connected the same way as the old switch. How was it connected. It reads like you have more then one ceiling light. Do you? If so what is the wiring at the other lights? Is this a 3-way circuit?
Old 06-05-14, 12:44 PM
D
The other ceiling light has the same 1 white, 1 black and ground, neither has a red wire.
Both lights come on at the same time when they were working.
At the switch end using a volt meter I have 120v touching red and white.
6v touching the 2 blacks,
Old 06-05-14, 01:49 PM
ray2047's Avatar
And what is black to ground? You seem to have a missing Jbox. Is there an unfinished attic above? If so I'd look there. An other possibility is a receptacle. Are any controlled by the same switch? If not I'd start opening receptacles working out from the switch.
Explanation: Most common way to wire the lights would be daisy chain but that would mean two cables in one of the boxes and you don't have that so they probably branch out from a box that is connected to the switch. Your problem may be in the unknown box.
Old 06-05-14, 02:12 PM
D
I just found out it is a 3 way switch. Sorry about the incorrect information.
Would I rewire the lights and the new switch the same way it was: Remember the lights would not
work before. I assume it was the dim switch causing the problem.
Old 06-05-14, 03:14 PM
ray2047's Avatar
You will need to use a 3-way dimmer. Depending on the type of 3-way dimer you may or may not be able to use a standard 3-way stitch on the other end. You may need to use a master and slave. The dimmer instructions will tell you what you need. Be sure you mark which wire is common before disconnecting the old switch
Old 06-05-14, 05:53 PM
D
Thanks for your help I think this will work.
