new ceiling light fixture, blown fuse, now not working
Received 0 Votes
I replaced my dining room pendant light. I blew a fuse when I was replacing it and I was able to flip the fuse box to get the other things on the same fuse back on. Once I was done with the install, I found the new fixture won't turn on. Can I fix this?
Sounds like you have a breaker box and reset a breaker not that you have a fuse box and turned the fuse box upside down.
Did you check the connections at the ceiling box and switch to see if any were loose? If the switch connections were back stabbed did you move them to the screws? Did you redo all the wire nut connections? If the light came with those fake wire nuts that have no spring inside did you throw them away and use real wire nuts?
You did turn the breaker off before changing out the light didn't you? You did connect the light exactly as the old one was connected didn't you. You didn't change any connections at the ceiling box did you?
Received 0 Votes
yes, the breaker box
thanks! It was fairly simple. Just had to connect the neutral and how wires and put the ground wire under the green screw. All those connections were tight. I had turned the power off, but needed to do something else (multitasking) and turned the power back on. I forgot I turned it back on and when I was putting the mounting plate on, there was a spark and the other light went off. I flipped the breaker and it came back on, so I was hoping there wouldn't be any problems. I turned the power off, completed the install and when I went to turn the light switch, nothing. The light doesn't come on.
