Is a light fixture ok as a load on GFI?
Old 06-15-14, 09:34 AM
H
Received 8 Upvotes on 7 Posts
I am remodeling a bath and installed a GFI outlet near the sink and then added the light above the mirror as a load. When I flip the light switch, it immediately trips the GFI. If I remove bulbs, closing the switch does not trip it.
Old 06-15-14, 09:43 AM
Tolyn Ironhand's Avatar
Received 893 Upvotes on 754 Posts
It should work fine. Check the wiring, I suspect you do not have the neutral passing through the GFCI.
Old 06-15-14, 10:09 AM
ray2047's Avatar
Best practice is to connect the light on line side but it should work on either side. Disconnect the light and see if the GFCI will reset.
Old 06-15-14, 10:19 AM
H
Many Thanks
Checking the wiring was the ticket. I did have the neutral running thru the GFI, but one of the neutral screws was loose. I sometimes think I am losing it at 69.
Old 06-15-14, 11:41 AM
ray2047's Avatar
I'm at 67 and can't find it sometimes. Thanks for letting us know you did.
