HELP!! Please, Ceiling light and fan wiring troubles
Old 06-15-14, 10:22 AM
N
Only three wires come from the ceiling, creamy, brownish red and copper, when removing old light fixture the black from the light was connected to the creamy, white to the brownish red, and the copper was grounded with bare wire. I assumed I would follow as if the brownish were white and the cream were black, but once all installed, nothing turns on?
Old 06-15-14, 11:15 AM
pcboss's Avatar
Received 204 Upvotes on 178 Posts
Do you have any means to test for voltage? Even a simple neon tester would work.
The fixture sounds like it was wired backwards, but that would not stop it from working.
Old 06-15-14, 11:20 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
If you are mounting a ceiling fan in place of a light fixture, make sure the box is "fan rated". Should be stamped into the metal or molded into the plastic. You can also tell by the larger screws used to hold the fixture.
