Old electric box won't fit new ceiling fan mounting bracket.
Old 06-20-14, 07:38 PM
G
Took old fan down and new fan mounting bracket is about a quarter to a half inch too wide for the box. Electric box screw hole to screw hole is 2.75 inches. New bracket has to have screws be at least a little more than 3 inches apart.
This box held a fan that is about the same size for 20 years without any stability issues.
So, are there any adapters that can make it wider, or do I have to install an older model fan or a completely new electric box?
Any help would be mucho appreciated.
Old 06-20-14, 08:22 PM
ray2047's Avatar
It is unlikely the old box is fan rated so best course of action is to replace it with a fan rated box. You probably have an old 3" box with ears that take 8-32 screws. You need a fan rated 4" box that has posts for 10-24 machine screws. No safe way to jerry rig it.
Old 06-21-14, 11:44 AM
G
Thanks for the quick reply.
I have attached a picture of the box. Can you tell if replacing it has to be done from the attic or not. I'd prefer not to go up there.
Old 06-21-14, 11:48 AM
Tolyn Ironhand's Avatar
Received 862 Upvotes on 725 Posts
That is not a fan rated box and will need to be replaced.
This is want you need: Westinghouse 15.5 cu. in. Retrofit Ceiling Fan Saf-T-Brace-0110000 at The Home Depot You should not need to go in the attic.
Old 06-21-14, 11:54 AM
ray2047's Avatar
You have conduit coming into the box so you will probably need access from above to change it out.
Old 06-30-14, 03:49 PM
G
A little update and a few more questions.
I cut around the box a little bit and removed this extension piece.Name:  IMG_0087.jpg
And here is what I am left with.
It is firmly attached to a bar going between the studs and has a couple of nails into a stud as seen on the right side of the pic.
The question remains, does this still need to be replaced with a newer fan rated box or is there is some kind of extension that can make up the 5/8 of an inch that the not wide enough round adapter used to inhabit?
Old 06-30-14, 05:57 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Is that piped in or is it flex? If it is flex remove that box and use it as a junction box in the attic ,install a fan rated box in it's place and run a new cable between it and the junction box.
Geo
