Switches to Dimmer Switches
Old 07-08-14, 09:52 AM
D
Hello everyone,
I have a question about wiring.
Currently I have the light in the living room which can be switched on/off using two different switches (1 is one gang and 1 is two gangs).
I would like to change those switches and install dimmer switches, is that possible?
If so, I need to buy a 2 way dimmer switch or what else?
Thanks, Dean
Old 07-08-14, 12:14 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No such critter as 2-way switch. You need either a 3-way dimmer that works wit a second non dimmer 3-way switch. Or a s master slave dimmer switch set.
