Ceiling fan light switch
Old 07-13-14, 02:37 PM
Hello,
I replaced my 2-wire light switch since the chain pulled out of the old one. The light works just fine, but for some reason my 3-way fan seems slower than before. All 3 speeds work fine, but it doesn't spin as fast.
Done anyone know what the problem could be?
Old 07-13-14, 03:05 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Which switch did you replace? The one in the wall or the one in the fan itself? Did you mess with the fan switch wiring at all?
Old 07-13-14, 03:56 PM
Hi Chandler - I replaced the light switch in the fan itself. I simply disconnected the one black wire from the blue wire and then disconnected the other black wire from the 3 black wires that are connected to the 3 lights. I installed the new switch exactly how the old one was black to blue and blue to the 3 black wires.
Old 07-13-14, 03:59 PM
chandler's Avatar
Does it have a remote control? The fan must be set at the highest setting via the chain for the remote to operate the lower speeds and still spool up to fast.
Old 07-13-14, 06:12 PM
Hi Chandler - no it doesn't have a remote control.
