Convert LED lights to battery powered ones
Hello all,
I hope someone can let me know if this is possible - I've looked at other threads but cannot see the exact same query.
I've recently purchased these fairy lights and would like to turn them in to battery powered ones if at all possible.
I go camping a lot and would like to use them when EHU is not available - is it possible/advisable?
Thanks in advance,
Christie
Thanks in advance,
Christie
Since they are LED there is probably a wall wort power supply powering the lights. Look at it and see what it's output voltage and watts are. Also make sure you notice if the output is AC or DC. That will tell you what voltage battery and how large you will need. Hopefully it will be something easy like 12VDC and you can just hook them up to a car or small sealed battery.
