Connecting a PL light bulb to the wall plug using a choke
Old 07-30-14, 02:33 PM
Hi,
I have these three components:
- a 9w PL light bulb
- a choke (transformer?)
- a wall plug power cable
I want to know what cable needs to go where in order for me to be able to plug the bulb to the wall with the cable. I asked at the electricity shop where i bought the choke but didn't get a decent explanation. I'm adding pictures with numbers so it'll be easier to explain what goes where.
Thank you!
All of the parts:
The choke from above:
The power cable:
The bulb:
The choke:
Old 07-30-14, 04:49 PM
ray2047's Avatar
Why? What is you purpose in Jerry rigging this? There are almost certainly better options whatever you goal is.
Not a choke but a ballast or hopefully that is what you have.
Old 07-30-14, 04:55 PM
Well, this is actually part of my girl friend's nail gel UV light drier. She got it off eBay but ordered a 110v version instead of 220v. Then when she plugged it in.. you know what happened. So i figured it's a lot cheaper just to buy the choke, and it was cheap, but i gotta have someone explain to me how to wire this thing up..
Old 07-30-14, 05:16 PM
Received 4,052 Upvotes on 3,635 Posts
Your location says NJ. You're talking about 240vac and you are showing a 120vac power cord.
Old 07-30-14, 05:21 PM
Originally from NJ, right now we're in Israel. Sorry, forgot to mention it.. She's used to 110v from the US, but here it's 220v, that's why she made the mistake.
Anyway, can it be done with what i got?
Old 07-30-14, 05:33 PM
Power cord.....
brown = 1 = L
blue = 2 = N
tube....
connection = 3
connection = 4
ballast.....
5 and 6 are the same
7 and 8 are the same
1 --> 5 or 6
2 --> 3
4-- > 7 or 8
Old 07-30-14, 05:36 PM
Well that's the kind of answer i was looking for
Gonna give it a shot.
Old 07-30-14, 06:10 PM
Well, it didn't work at first, but then i changed it a bit, i did:
2 --> 5 or 6 (blue instead of brown)
1 --> 3 (brown instead of blue)
4 --> 7 or 8
Now works like a charm!! Thank you!
