Wiring outlet with fan?
Old 07-30-14, 08:34 PM
T
Hello. I need some help please.
I have no idea how to wire this outlet. Name:  photo.jpg
That is how its been wired and the fan has never worked. But the outlets do.
Old 07-30-14, 08:56 PM
Received 1,353 Votes on 1,251 Posts
Welcome to the forums.
I see a receptacle there with a red, black and white wire connected. It looks like the jumper on the receptacle between the red and black wires is missing or has been removed.
Does the black wire on the receptacle connect to the switch ?
With that receptacle split like that..... either only one half of the receptacle works or one of the sides is switch controlled or you have two circuits to that receptacle.
Old 07-30-14, 09:46 PM
T
Thanks.
And thanks for your time sir. Both outlets work. Checking with my multimeter both the red and the black are giving 124v
Old 07-30-14, 09:47 PM
Am I correct..... the jumper is missing on the receptacle ?
If yes.... please measure from the red to the black for me.
Old 07-30-14, 10:04 PM
T
It is missing. And I get 250v.....
Old 07-30-14, 10:20 PM
Ok.... be very careful there because obviously you have 250vac which is high voltage. That is a multiwire branch circuit. It's controlled by two circuit breakers.
You may want to turn off BOTH breakers while working in that box.
We need to see the wire connections inside the box if you can carefully pull them out.
Old 07-30-14, 10:38 PM
T
Hope you can see it.Name:  photo.jpg
Old 07-30-14, 10:40 PM
One more picture from a little further out so we can see how the wires connect to the devices.
Old 07-30-14, 10:48 PM
T
I've removed the switch. But the two black on the right were connected to the switch.
Old 07-30-14, 11:38 PM
is their only one fan box in the room.
could you drop the trim on the fan and tell us what cables you have at the fan box.
one cable,black,white,ahd ground. or 2 cables with what color wires.
Old 07-30-14, 11:46 PM
T
Hi John. There is only one fan. There are 3 wires. Black, white and ground.
Old 07-31-14, 12:15 AM
T
It seems to be wired right? Perhaps the fan is dead??
Old 07-31-14, 02:27 AM
break the white wire ,in the switch box,between the 2 blacks that went to the switch.
you now have 2 cables with a black,white,and ground.
take a meter and see if either of them go to the fan box.
if you fine one that works,use the power in the receptacle to feed the switch and the fan.
cap off the black and white of the unused cable. don't cut off the wires-you may fine a use for them some day.
Old 07-31-14, 08:00 PM
T
I did that and got the outlet and the fan working but lost power to another outlet
Old 07-31-14, 08:36 PM
In your box I think I see 2) three wire cables and 2) two wires cables.
The three wire cables are connected red to red, black to black, and white to white.
Those connections must be maintained as those circuits only stop by there on their way to other places.
Now you've determined that one of the two wire cables goes to the fan. The white wire connects to the white connection of the three wire cables. The black goes to one side of the switch. Then a short jumper from the other side of the switch to either the red connection or the black connection.
The white and black of the last two wire cable should be wire nutted off.
It is imperative that this wiring be done correctly. Since you have a multiwire branch circuit there.... a mistake can apply 240vac to receptacles on those circuits.
Old 08-01-14, 12:19 AM
T
Thank you very very much PJMax. Everything is working....except my sanity.
Old 08-02-14, 12:19 PM
Glad everything is working now.
Have a and get your sanity back.
