Replacing light switch wiring question?
Old 07-31-14, 07:35 PM
D
Received 1 Upvote on 1 Post
The light that this switch operates is also operated by another switch at the other end of the room.
After removing old switch (pic 1) & (pic 2) colored wires marked & installing new switch (pic 3) & (pic 4) colored wires marked, the light will turn on & off using the new switch but it will not turn off using the second switch. Also if the light is off the second switch will turn the light on. Any suggestions on what I did wrong would be appreciated.
I thought I add 4 pictures but they are not showing?
Old 07-31-14, 07:41 PM
Received 3,982 Upvotes on 3,574 Posts
I checked.... your pics are not uploaded. http://www.doityourself.com/forum/el...-pictures.html
If you replaced a three way switch..... look at the old switch and look at the new switch. There is a dark colored screw on each switch. The wire that was on the dark colored screw on the old switch must go to the dark colored screw on the new switch.
Old 07-31-14, 08:13 PM
ray2047's Avatar
When you upload your pictures switch to basic uploader. There is a problem with the advanced uploader.
Old 08-01-14, 05:21 AM
D
Size:  28.3 KBName:  pic 2.jpg
Size:  31.3 KBName:  pic 3.jpg
Size:  27.2 KBName:  pic 4.jpg
Here are the pictures for my previous question (see #1), thanks
Old 08-02-14, 11:12 AM
I see your bottom picture. I see three "push in" holes but I don't see three screws.
Old 08-02-14, 11:19 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
The screws on the new switch are the same as the push in holes ie: 2 connections. A 3 way switch has 3 connections.
