What size Dimmer Switch do I need?
Old 08-10-14, 12:30 PM
T
I have just fitted:-
16 Dimmable electronic transformers in parallel
Prim: 240v-50/60Hz, 0.26A
Please could you confirm that is this equivalent to 60w each?
I worked this out that for 240v = 1A so 0.26A is 63w?
(63*16=1008) So I need a dimmer switch that is capable of switching over 1kw at least?
Thanks
Old 08-10-14, 12:37 PM
Received 4,122 Upvotes on 3,702 Posts
Welcome to the forums.
A +1000 watt dimmer would be extremely large.
You used the maximum amperage transformer number.
What bulbs or lamps are you using ? Your actual wattage may be nowhere near that high.
Old 08-10-14, 12:42 PM
T
I am using MR16 50w 12v lamps for each of the 16 fittings
Old 08-10-14, 01:24 PM
Ok.... so your load would be close to 1000 watts. 16x55= 880 watts.
You'll need to search for 240v 1000w magnetic transformer dimmer.
Lutron lists 277v dimmers but I haven't found any for 240v yet.
