Go Back  DoItYourself.com Community Forums > Electrical, AC & DC. Electronic Equipment and Computers > Lighting, Light Fixtures, Ceiling and Exhaust Fans
Reload this Page >
Wiring Single Pole Switch with power at Light and Load (receptacles) at Switch
Old 08-18-14, 06:11 AM
D
Hello,
I'm in the process of upgrading the switches, receptacles and lights in my house and ran into the following situation. Power going into the light (2 wire) then a cable (3 wire) cable between the light and the switch (single pole) and finally a cable (2 wire) next to the switch which feeds receptacles in the room - how do i go about wiring this as i'm a little rusty on my wiring skills.
Old 08-18-14, 07:30 AM
ray2047's Avatar
At the light:
  • Black of power in to black of 3-conductor cable.
  • Black of light to red of 3-conductor cable.
  • All whites connected together.
  • Grounds per code.
At the switch:
  • Black of 3-conductor and black of 2-conductor connected to a pigtail.
  • Pigtail to one side of the switch.
  • Red to other side of switch.
  • All whites connected to each other.
  • Grounds per code.
Old 08-18-14, 08:20 AM
D
Thank you - will try this once i get home tonight - will post update
Old 08-19-14, 08:51 AM
D
That worked! I had one wire (red @ light) mixed up - much appreciated.
