Is it a ceiling fan box?
Old 08-18-14, 12:58 PM
G
Hi everyone,
A first time poster. I've read some of the other posts about this topic but am unsure. I can't find any stickers/writing saying whether it can support a fan or not. Any help is appreciated! I just want to hang a small ceiling fan where this plain light fixture used to be.
Thanks,
Len Grosso
Old 08-18-14, 01:15 PM
ray2047's Avatar
If it has ears and uses 8-32 screws it is not fan rated.
Old 08-18-14, 02:28 PM
G
Thanks for your help! Are you talking about the screws that attach the light fixture bracket to the box? Also its halfway between the joists, I don't know if that helps? I also added one more image that is from a slightly different angle.
Sorry this is my first time retro-fitting a ceiling fan.
Lenny
Old 08-18-14, 03:20 PM
Handyone's Avatar
You want to replace your existing box with this:
The hardest part is getting the old box out, if you have an attic it helps a lot.
If you don't have an attic above, post back for some tips on getting old box out.
Old 08-18-14, 03:23 PM
ray2047's Avatar
Yes.
Old 08-18-14, 03:51 PM
G
No attic so I guess I will have to remove it then install the new one. I'll look for a how to online, but any tips?
Lenny
Old 08-18-14, 04:07 PM
is the box screwed up to a block of wood.
if so.......you may use long screws and mound the fan to the wood over the box.
Old 08-19-14, 07:57 AM
G
I don't think so. It's suspended halfway between the joists so there isnt anything around it.
Old 08-19-14, 11:08 AM
Tolyn Ironhand's Avatar
Received 915 Upvotes on 773 Posts
The screw I have circled makes me believe it is screwed into some framing. You might be able to swap it out with a 1 1/2" deep fan box. Otherwise Handyone's box will do the trick.
Old 08-19-14, 04:55 PM
pcboss's Avatar
Received 208 Upvotes on 181 Posts
No need to change the box. It is fan rated. You can see the screw also goes into the back of the box. Look near the bl/or wire nut on the right side.
