Question on Conduit fittings?
Hello - I'm looking for a clean way of getting romex out of my garage wall and onto the ceiling. I've gone through the various fittings and boxes at home depot and lowes and the only solution I see is using a junction box near the ceiling and then attaching the conduit to that. Is that the best solution, or is there something better? The purpose of this is to run new lighting and electrical outlets mounted to the ceiling.
Thanks in advance.
Thanks in advance.
A junction box is your best choice. This way you can convert from NM cable to conduit and THHN type wire
run your nm cable from your wall box up to the top of the wall and out on to the ceiling to your first device box. buy some PVC flex conduit long enough to cover the wire into the wall 6 inches or so........no need for a box at the wall.
you can keep on using carflex on the ceiling or you can use hard gray PVC conduit.
you can use NM in the pipe or single wires.
