Can lights in kitchen
Old 08-23-14, 08:41 AM
L
I am looking to replace a 4ft 2 bulb fluorescent light fixture in my small kitchen. It is 11x11' with a single incandescent fixture over the sink. How many 6 inch cans should I use and can I run them all on one switch. I am going with 10 watt led inserts. There will also be under cabinet lights added. Thanks
Old 08-23-14, 08:56 AM
Handyone's Avatar
I would install at least 4 can lights, maybe more depending on how you want to space them.
This is not including light over sink.
Even only 4 can lights will put out a lot more light than your old fixture, you'll see a drastic difference. If it's too bright you can use a dimmer.
The sink light should be on it's own switch.
When adding the U/C lights, it would be nice to have them switched separately also.
You can get help here on how to add separate switches and so forth.
Old 08-27-14, 04:51 PM
give us a floor plan.
i could probibly put in 6 or so.
sounds good.......1 switch is fine. 14-2 from box to box.
Old 08-28-14, 12:29 AM
pcboss's Avatar
Received 204 Upvotes on 178 Posts
You are going to need to look at the light distribution cone to determine the spacing. You do not want light and dark areas, especially in a kitchen.
