Can I Use the Honeywell Econoswitch Programmable Timer ?
Old 08-29-14, 10:48 PM
Hello everyone,
I'm new to the forum and an absolute noob when it comes to doing anything involving electrical. I will very likely hire an electrician to install the Honeywell Econoswitch (RPLS740B). But first, before I even start making phones call, I thought I'd ask if my setup will even accommodate this particular switch. I've attached a photo. The top switch controls my outdoor front porch light and light attached to my garage. The bottom switch controls my indoor entryway light. I'd like to have these lights controlled by the Honeywell, if possible.
If anyone can let me know based on this photo if using this switch is even an option, I'd appreciate it. I also realize there's a lot more that needs to be known underneath it all to know for sure. Thanks for any help.
Old 08-29-14, 11:22 PM
D
I'm no sparky, but I'm thinking no. The honneywell appears to only control 1 device, you have 2.
Old 08-29-14, 11:26 PM
Received 4,086 Upvotes on 3,669 Posts
Welcome to the forums.
It looks like your switches are in a wiremold box and supplied with a piece of wiremold from the bottom and another at the top. Right off the bat that box may not be deep enough to fit the Honeywell control.
We'd also need to know how many and what colors are in the wiremold and connected to the switches. As a guess I would say that the wiring would support the timer but depth is an issue.
Old 08-29-14, 11:37 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Here is a link to something you might think about.
Review: Honeywell EconoSWITCH Programmable Timer | Steve Jenkins' Blog
Scroll down to the picture of the 3 switches you could do that in 2 controllers. Bit more work and more time for electrician but not that much and you would have a updated look.
Old 08-29-14, 11:45 PM
There is some reason why the wiring on that wall is in wiremold.
Wiremold boxes are as a rule fairly shallow.
