Wireless light switches??
Old 08-30-14, 03:37 PM
G
Soliciting advice and opinion:
I have a back porch the width of my house. Walls are brick, ceiling is nice old beadboard. Don't want to get to invasive for something simple.
On one end of the porch, I have a light fixture. I'd like a like a light fixture over the other half of the porch, which is the seating area. I don't mind running a discreet cable from the existing light to the new light, but don't really want to then run a cable to a switch, which would require conduit, etc. And would prefer not to have a pull string dangling either.
What about a wireless light switch? I've seen them on the shelves at the hardware store. Seems like a good solution.
Old 08-30-14, 04:19 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
If you wire the light from the existing fixture, you won't need another switch. Wireless switches still require hard wiring to the fixture, unless there is a remote unit mounted in the fixture similar to ceiling fans.
Old 08-30-14, 04:32 PM
G
I should've been more clear, I'd like to be able to control the lights independently. They're quite far apart. The power comes into the existing light fixture, so I will tie into that and run to the new light.
In other words, the existing light isn't really part of the equation.
Old 08-30-14, 04:54 PM
chandler's Avatar
If you can get uninterrupted power to the second light you may benefit from remote control RF switches Remote Switches > Self-Powered Wireless Controls > Lighting Controls > Products from Leviton Electrical and Electronic Products
You would need a receiver in the fixture and the switch would mount on the wall surface.
Old 08-30-14, 05:10 PM
G
I think that's what I'm looking for.
So anybody that has used one, satisfied?
