is it ok to fix ceiling fan to joist?
Received 0 Votes
I have a ceiling fan which has it's round electrical box attached to a 1/2" bolt which in turn is attached to a steel flat bar which is nailed between two joists.
This setup is quite loose, perhaps it's intended this way to find its own level but i kind of want to just screw in the circular electrical box directly onto the joist.
Is this wise? or should i leave it the way it is. The fan shakes a little and i wondered if this would improve things.
cheers
oman
cheers
oman
The box in the picture does not appear to be rated for ceiling fans nor does the described mounting. Here is an example of a correct box and how it is install, Notice the fan is held by 10-24 screws into threaded tubes not by 8-32 screws into tabs with only a couple of threads.
If you didn't switch to the style that Ray has shown then you need to change that lighting pancake to a fan rated pancake box. The flat metal bar is completely unsatisfactory for hanging a fan. Fastening a pancake box directly to the bottom of a beam is ok.
Previous Thread
Next Thread
