Determing Hot/Neutral from swag cord
Hello all;
I am replacing old ceilings fan in my spare rooms. They were just screwed into a beam, with the wiring done with a swag cord. The swag cord is white with only 2 wires, so no ground. Anyway, in order to wire my new ceiling fan I need to know which wire is hot (black) and neutral (white). Both wires are white and I can find nothing to indicate which one is hot.
Ive tried using a voltage tester but it appeared to show each wire as hot. So does it matter which swag cord wire i connect to my fans black wire, and the other to white? How would I tell which one is black?
Yes i know i should have taken a pic before disconnecting the old fan, but it was not resting on a bracket when i removed the 3 screws it literally fell off the ceiling.
Thanks
Thanks
Technically that is not a code compliant method of wiring for a fan.
How do you get power to the white zip cord ?
I'm not an electrician so i dont care if its not fully code compliant. I just want to know which wire goes to which. My swag cord is a typical white cord with a chain with a 2 prong plug on the end, such as this one on amazon:
Robot Check
Robot Check
Ribed conductor is usually neutral. Verify with a multimeter set to ohms Wide blade is neutral. If plug isn't at least polarized it shouldn't be used.
But the other people it may hurt do. Code isn't about being an electrician. It is about safety.
