Heavy light shade and a plaster ceiling rose
Old 09-03-14, 01:43 PM
3
Hello!
I have purchased a large 1940s style factory light shade for our living room which weighs 5kg, so this will need to be hung from a joist/noggin. Thats fine and I can do this. The problem I have is that there is an ornate Victorian plaster ceiling rose, the centre of which drops about 5inches from the ceiling. How would I go about fixing a steel ceiling rose with hook to the joist through the plaster rose? Is it as crude as a pair of 7inch screws going straight through the plaster rose and into the joist?
There is a manufactured hole through the middle of he plaster rose for the cable drop, so I could potentially run the chain from the light fitting through this hole to a hook on the joist - thus eliminating the need for the steel ceiling rose hook; however this would mean the chain and cable simply disappears into the ceiling via the cylindrical hole in the plaster rose. Would this be visually inappropriate - I have tried to find an image of this on google but I'm struggling, so it's either my search terms or this simply isnt the done thing??
Thanks for any and all replies
Andy
Old 09-03-14, 02:10 PM
Received 94 Votes on 83 Posts
Welcome to the forums. Can you give us some pictures?
http://www.doityourself.com/forum/el...-pictures.html
Old 09-03-14, 05:04 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Since this is an electrical/lighting question I have moved it to the lighting forum. If this is just a shade and not an electric light let us know.
You don't mention a junction box. If this is a light you need a junction box.
