hurricane lantern Table Lamp
Old 09-10-14, 06:52 AM
D
Hurricane Lantern Table Lamps
I have two metal hurricane lanterns I'd like to wire up as table lamps, using candelabra CFL or LED bulbs:
Home Hardware - LED Hurricane Lantern
I'm trying to determine if these switches would be suitable, the voltage should be fine for 120v but not sure hot to determine the amperage?
SERVALITE 3-Amp Black Single Pole Switch at Lowe's Canada
Any advice would be much appreciated, thanks.
Old 09-10-14, 07:08 AM
D
Should also mention I've removed the LED assembly, reflector and battery pack...
128 Traditional Led LanternWorld Famous Sales of Canada
... and this is the socket I plan to use:
SERVALITE 250-Watt Black Hard-Wired Light Socket at Lowe's Canada
