fluorescent light replacement question
Old 09-10-14, 07:19 AM
H
My neighbor called me over because she has two lights above her sink that wouldn't work, and when she replaced them it didn't do anything. Both either have a faint orange glow at the ends or flicker on for a split second before going dark again. I am not familiar with the terminology, but the two plastic terminals/endpoints with the twist/metal contacts are apparently called "bulb holders." I took them out to make sure each end was properly secured to the bulb, but it made no difference. By accident I noticed that if I twisted one end in and touched the other end of the bulb with my fingertip, the bulb lit up and stayed lit. Does this indicate a problem with the bulb holders, and should the entire fixture be replaced? I noticed you can buy replacement holders but they aren't a standard shape (current ones are different than I found and snap in, so may be based on manufacturer).
Old 09-10-14, 07:22 AM
H
Also, I should mention that this light is about 28 years old.
Old 09-11-14, 08:49 AM
P
Temporarily Suspended
I really can't picture exactly which fixture she has but if the fixture is 28 years old, you might as well replace it.
Old 09-11-14, 10:05 AM
H
They are like these, but yes, I told her to get a new fixture the same size.
Old 09-11-14, 10:09 AM
P
That's what I thought it was & they are replaceable.
