Emergency Lighting
Old 09-15-14, 07:18 AM
R
Emergency Lighting
Will emergency light bulbs go on if the battery is dead when the test button is pushed? I assume "no," so then connection to AC power is only for trickle charge purpose?
Old 09-15-14, 08:11 AM
Received 4,144 Upvotes on 3,722 Posts
That is correct. The AC is used to trickle charge the battery and when it's lost to automatically connect the lights to the battery.
Old 09-15-14, 09:53 AM
R
Thanks for the confirmation. I replaced the battery with a new one, but still no light when I pushed the test button. If the bulbs are good, is the fixture shot, or should I be looking at another possible cause?
Old 09-15-14, 09:49 PM
Check the bulbs first. Usually when you push the test button..... that indicator/charge light will go out, you'll hear a click and the emergency lights come on.
