Ceiling Fan: Adding the functionality of a remote to an existing wall switch
Old 09-23-14, 01:29 PM
Hi,
I have a ceiling fan that has a very old remote in a kitchen area. The remote controls the fan speeds as well as a light hanging from the fan. The remote has problems with it & we always misplace it. I could probably replace the remote, but we never use it and would like to add the funtionality of the remote to an existing on-off switch. I have electrical experience and have added / replaced several fans in my life, but I'm a little stumped on this. I'm guessing I would have to run additional wires from the fan to the switch?
Thank you
Old 09-23-14, 02:26 PM
Temporarily Suspended
It depends what wires are coming out of the fan. Consider buying a fan without a remote.
Old 09-23-14, 05:32 PM
Handyone's Avatar
This is a little hard to understand. But I think you want to be able to control fan, light, separately from an existing switch?
Yes, you would need to run new cable from switch box to fan box.
Assuming a 15A lighting circuit, you would run #14/3 with ground.
If you're willing to run new cable, someone here can help with the wiring part.
14/3 contains a white neutral, and 2 hot, black and red.
Old 09-23-14, 05:52 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Does the fan have separate light and motor hots (blue and black)?
Old 09-24-14, 10:23 AM
I'm not sure. I'll have to get up there and take it apart to see.
