Indoor Flood Lights Constantly Blinking
Old 09-27-14, 08:20 AM
D
There are 3 floodlights in my kitchen ceiling that are attached to one switch. One of these lights started flashing quickly (like a strobe light) a few weeks ago. I had to turn the dimmer switch to off to stop it. I checked the bulb and it's fine. Then for a few days, it was okay. Now they are all flashing at once and there is a humming sound coming from the switch. I don't know anything about all this. Do I need to call an electrician? Is it dangerous? Thanks in advance for your help.
Old 09-27-14, 08:35 AM
Received 4,154 Upvotes on 3,730 Posts
Welcome to the forums.
Most of the cans have thermal switches that shuts off the bulb if the fixture gets too hot.
It could be a bulb just slightly too big for the fixture or the heat sensor is going bad.
Have you replaced the bulb recently ?
Old 09-27-14, 08:46 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
It might also be possible that the switch is bad if they are all cycling off at the same time.
The switch could be bad or the wattage of the bulbs exceeds the switch capacity.
Double check the bulb wattage and compare that to what the fixture is rated for then compare the total bulb wattage to the switch rating.
Old 09-27-14, 09:25 AM
I hadn't read that all the lights were flashing at the same time. That would most likely require a switch replacement.
Old 09-30-14, 06:45 PM
A
Received 296 Upvotes on 271 Posts
Are these incandescent or fluorescent or LED? (Floodlights may have any of these three technologies inside.)
You may have fluorescents that are not compatible with your dimmer.
