Flourescent lights dim after ballast replacement
Old 09-29-14, 05:51 AM
I changed the T12 ballast out after it started flickering. With the new T12 ballast, the lights are significantly dimmer. When I changed the ballast, I joined the old wires with wire nuts. Is this ok? Is it just a bad ballast that I got?
Old 09-29-14, 06:07 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Was it the correct ballast? Not just any ballast will work. It must be for the bulbs your fixture uses.
Old 09-29-14, 06:08 AM
I think so. The old one says T12 and so does the new one.
Old 09-29-14, 06:10 AM
ray2047's Avatar
No, T-12 isn't enough you must match the length or amp of your bulbs and the number of bulbs. It will say something like T12 2 tube 4 foot with actual description matching your fixture.
Old 09-29-14, 07:56 AM
Received 194 Votes on 180 Posts
Yea, T12 primarily describes the diameter (1 1/2") of the bulb and the pin arrangement on the end. T12's are available in 15-125 watts so you need to look at more than just the T12.
Old 09-29-14, 09:45 AM
I went and took the old ballast and they gave me the same one, but said to try changing the bulbs.
Old 09-29-14, 12:15 PM
ray2047's Avatar
If you are going to replace the bulbs you might just want to convert the light to T8. T12 bulbs and fixtures are being phased out. A T8 will fit a T12 socket but the ballast and wiring will need to be changed.
Old 09-29-14, 02:07 PM
I may do that since it's about the same price.
