Can I replace a wall mounted knob (fan speed control) w/ dimmer switch?
Old 10-01-14, 12:06 PM
L
I have a triple switch wall plate in my master bedroom, which has 2 light switches (one on either side) and a knob in the middle, which controls the ceiling fan speed. The knob has 4 settings, iterated twice on the knob: Off, low, medium, and high.
I want to replace the wall plate, switches and knob, but don't know what is compatible with the rotary knob in the middle. Can I replace it with a dimmer switch of some kind?
Any insight and/or guidance would be greatly appreciated.
Thank You,
Sarah
Old 10-01-14, 12:46 PM
ray2047's Avatar
No, apples and oranges. Does the fan have a pull chain speed control also? If so you can just eliminate the speed control and wire the fan always hot or use a regular switch. (Note some will advise the fan should always be started on high which makes a wall switch less ideal.)
Old 10-02-14, 04:50 AM
pcboss's Avatar
Received 204 Upvotes on 178 Posts
Motors need to have a speed control used, not a dimmer. A dimmer is not made for use with motors and would cause a failure of the motor or dimmer.
