Stand Lamp Wiring - Question
Old 10-02-14, 11:45 AM
Stand Lamp Wiring
My stand lamp has the electrical wiring running through the standís pole and then through an adjustable extension to the socket. I am trying to replace the electrical wiring. The picture is the extension. As you can see, the extension has right angle turns throughout its length. I had great difficulty pulling through the old wiring.
The center of the extension does not come apart.
Is there a method I can use to thread new wiring through this extension?
Thanks,
Jerry
10/2/14
Old 10-02-14, 11:55 AM
Received 340 Votes on 318 Posts
Welcome to lamp rewiring 101..........
You use the old wire to pull the new wire in.
A small bit of dish detergent makes the wire slide easier.
In the center part of that knuckle.... there should be a cap that snaps off.
Old 10-02-14, 07:11 PM
Here is an update.
In my case, pulling the old wire through all the right angles was extremely hard and knowing that connecting a new wire would make it even more difficult, I did not try it.
Yes, there is a cap where you mentioned. So to finally remove the old wire I cut the wire under the cap and only then could I remove the old wire in sections. And when I did remove the cap I was hoping to find a screw or something that would allow me to separate the two metal sections. No such luck. Those two sections are permanently attached to each other.
So, this is finally what I did. I got a smaller size electrical wire and after much push and pull, I was able to thread the wire through the two sections. It was not easy, but I am now back in business. I just wonder how the manufacturer threads the wire.
Thanks for your input.
Jerry
Old 10-02-14, 07:40 PM
You're welcome. Glad you got it done.
Yes... those swivel points are crimped together. It can be quite a job getting the wire thru all those bends.
Old 10-02-14, 07:51 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
What gauge and type of wire?
Old 10-03-14, 07:35 AM
Hello Ė
I wish I could tell you the gauge, but the wire was a line cord I had cut off an old appliance years ago. The wire insulation and wire size were smaller than what I removed.
Jerry
