Help with old range hood fan
Old 10-02-14, 08:12 PM
The casings of the wires of the fan in our range hood have completely dried out and are falling apart. As a result the bare wires are exposed in a couple of places. I could put electric tape over those places, but the problem is the wire is exposed even right where it enters the motor. So, I thought I would open it up, and install a new wire. However, I am having a hard time figuring out how to open the thing up, and would greatly appreciate any help.
I could see two screws only, and thought those were what were holding it together, but it seems that their only function is to connect the motor to the mounting bracket. I am not sure if the 4 tiny holes on the model number plate are actually rivets that hold the whole thing together.
Size:  29.5 KBName:  IMG_6452.jpg
Size:  26.6 KBName:  IMG_6453.jpg
If this can't be done, if someone could point to a reasonably priced replacement fan, that would be great too. The only thing that I can find that looks similar is this, Amazon.com: Broan Replacement Range Hood Fan Motor and Fan - 2 Speed # 97012248, 1.1 amps, 120 volts: Appliances which has terrible reviews.
Thanks for your help!
Old 10-02-14, 08:46 PM
Received 2 Votes on 2 Posts
Welcome to the forums. Does your range hood have a brand name on it anywhere? There is some information on the data plate on the motor. If you can provide some additional information, we may be able to help.
Old 10-02-14, 09:24 PM
Thanks for the reply, goldstar. The wording on the plate is as follows
20 Auto Oil Every 3 Mo.
Universal Electric Co.
Made in Owosso, Mich., USA
C.S.A. Approval No.
Duty..........................11N
Amps.......................R.P.M.
.5.............................16000
Cycle.......................Volts
60.............................115
Model......................Serial
118-036....................17726
I tried searching for the model number, but didn't find anything. It came with the house we just baught, so I have no idea how old it is, but it's probably pretty old.
Old 10-03-14, 07:29 AM
Received 334 Votes on 312 Posts
Old 10-03-14, 08:56 PM
Thanks a lot for the links PJmax.
I don't understand how I missed your second link when I searched earlier. Now it shows up as the first search result.
