Photocell for outdoor lights broken - always on
Old 10-05-14, 04:40 PM
F
My outdoor lights are controlled by a photo sensor attached to the bottom of the outdoor breaker panel. The lights are always on. That is especially becoming a problem now, because I'm using those lights to power the strings of LED lights I put on the roof for Halloween and Christmas decorations. Can someone help out with how to replace this unit and where/what kind to replace it with?
Old 10-05-14, 05:50 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Welcome to the forums! Most electrical supply houses and some box stores will carry compatible photocell units. It is a matter of taking a picture of the wiring inside the panel and removing the power to it. Remove the wiring and unit, replacing with one of the same features and rewiring it according to the picture you took on your phone. Restore power and give it a little time to work.
Old 10-05-14, 06:43 PM
Received 4,094 Upvotes on 3,677 Posts
Some photocells don't like to be used upside down and leak water internally.
One like shown below works good upside down. You should be able to find this style at the big box stores or an electrical supply house.
Old 10-06-14, 03:06 AM
chandler's Avatar
Another style allows for you to meter the amount of light it allows into the photocell. Helpful in areas with too high light, or reflected light.
Old 10-06-14, 08:36 PM
F
It looks a lot like this one, just a slightly more compact design...and it IS mounted hanging from the bottom of the box. So pretty straight-forward, huh? Only drawback is having to turn off power to the whole house while I do the replacement.
Old 10-07-14, 02:45 AM
chandler's Avatar
Why the whole house? Just turn the power off to that particular circuit.
Old 10-07-14, 07:49 AM
You should find the photocell connected with three wires..... red, black and white. There should be splices within 6" of the cell. If you follow the black wire - it should connect to a breaker. Turn that breaker off.
