switch for Broan QT130LE
Old 10-11-14, 07:34 PM
I
Thanks in advance for any advice...
I am installing a Broan QT130LE fan/light/nightlight.
I have a single gang switch right now at the bathroom door. This switch currently controls the existing ceiling light (that will be replaced by the new light) and the vanity mirror light.
What would be my switch options to run the fan on a timer, the ceiling light, nightlight and then also the vanity? I suppose I will need a two-gang box with one switch solely for the fan and then use a separate Broan three-function switch for the ceiling light, nightlight and vanity/
I really don't need the nightlight option of this new light, so I suppose I could just not wire that.
How reliable are those switches that operate on a humidistat?
Thanks.
Old 10-11-14, 08:44 PM
Received 4,104 Upvotes on 3,686 Posts
Very reliable and just about useless.
If you want or need the fan on..... turn it on.
If you are afraid of leaving it on when leaving.... put a countdown timer on it.
Old 10-12-14, 02:57 PM
I
Thanks PJmax...I guess that was the actual question I was asking...if the switches actually switch on and off the fan when the humidity gets high.
I am thinking a timer in one box and a 3-function switch in the other box for the Broan light, Broan nightlight and the vanity lights. Does this sound like the best switching option for what I described earlier. Thanks in advance.
Old 10-12-14, 03:00 PM
Sounds like a good choice. You'll need to see how much room you available in the wall for expansion. You'll need at least another gang on that box or a second separate box.
